To change the wireless network settings of the printer, connect the printer and the computer with a USB cable temporarily. If you modify the wireless network settings of the computer over wireless connection without USB connection, your computer may not be able to communicate with the machine after modifying the settings.
Note
Start up IJ Network Tool.
Select aprinter in Printers:.
When the printer is connected to the computer with a USB cable temporarily, select the printer with "USBnnn" (where "n" is a number) appearing in the Port Name column.
Select Configuration... on Settings menu.
Click the Wireless LAN tab.
The Wireless LAN sheet is displayed.
For more on the Wireless LAN sheet, see Wireless LAN Sheet.
Change or check settings.
Note
Important
If all encryption types of the wireless router, printer, or computer do not match, the printer cannot communicate with the computer. If the printer cannot communicate with the computer after the encryption type of the printer was switched, make sure encryption types for the computer and the wireless router match that set to the printer.
If you connect to a network that is not protected with security measures, there is a risk of disclosing data such as your personal information to a third party.
SSID:-
Enter the same value that was set for the target wireless router.
When the printer is connected with USB, the Search screen appears by clicking Search.... Set the SSID of the wireless router by selecting the one of the detected wireless routers.
Search Screen
Encryption Method:-
Select the encryption method used over the wireless LAN.
You can change WEP settings with selecting Use WEP and clicking Configuration....
Changing WEP Detailed Settings
You can change WPA/WPA2 settings with selecting Use WPA/WPA2 and clicking Configuration....
Changing WPA/WPA2 Detailed Settings
TCP/IP Setup:-
Sets the IP address of the printer to be used over the LAN. Specify a value appropriate for your network environment.
Click OK.
After changing configuration, a screen is displayed asking you for confirmation before the settings are sent to the printer. If you click Yes, the settings are sent to the printer and the Transmitted Settings screen is displayed.
Note
