Allows you to set the printer with wireless LAN connection.
To display the Wireless LAN sheet:
- Start IJ Network Tool.
- Select the printer in Printers:.
- Click Configuration... in the Settings menu.
- Click the Wireless LAN tab.
Network Type:
Displays the wireless LAN mode currently selected.
Note
When Direct Connection is displayed on Network Type:, you cannot change the settings on the Wireless LAN sheet or the Admin Password sheet.
You can change or check the settings from Set up printer's direct connection... in the Settings menu when you use the printer with the direct connection (access point mode).
Changing Settings in Direct Connection
- Infrastructure
Connects the printer to the wireless LAN with a wireless router.
- Direct Connection
Connects external wireless communication devices (e.g. computers, smartphones, or tablets) to the printer using it as an access point (wireless router).
SSID:
The network name (SSID) of the wireless LAN currently used is displayed.
Note
In the direct connection (access point mode), the access point name (SSID) of the printer is displayed.
As the initial settings, the unique value is displayed.
Search...
The Search screen is displayed to select a wireless router to connect to.
Search Screen
Note
Encryption Method:
Select the encryption method used over the wireless LAN.
Do not use-
Select to disable encryption.
- Use WEP
Transmission is encrypted using a WEP key you specified.
If a WEP key has not been set, the WEP Details screen is displayed automatically. To change WEP settings set before, click Configuration... to display the screen.
Changing WEP Detailed Settings
Use WPA/WPA2-
Transmission is encrypted using a WPA/WPA2 key you specified.
The security has been strengthened more than WEP.
If a WPA/WPA2 key has not been set, the Authentication Type Confirmation screen is displayed automatically. To change WPA/WPA2 settings set before, click Configuration... to display the WPA/WPA2 Details screen.
Changing WPA/WPA2 Detailed Settings
Configuration...
The detailed settings screen is displayed. The WEP or the WPA/WPA2 key selected in Encryption Method: can be checked and changed.
For more on WEP setting:-
For more on WPA/WPA2 setting:-
TCP/IP Setup:
Sets the IP address of the printer to be used over the LAN. Specify a value appropriate for your network environment.
- Get IP address automatically
Select this option to use an IP address automatically assigned by a DHCP server. DHCP server functionality must be enabled on your wireless router.
- Use next IP address
Select this option if no DHCP server functionality is available in your setup where you use the printer, or you want to use a particular IP address or a fixed IP address.
