Learn how to use the Easy Wireless Connect method to connect the PIXMA TS5020 wirelessly.
If your Mac has macOS® 10.15 or later installed, the driver and software package for this printer is not supported on your computer, follow this link to learn how to wirelessly set up your printer on a Mac with macOS® 10.15 or later.
Prior to starting setup on the computer, start the Easy Wireless Connect process on the printer. Then complete the setup on the computer.
The setup process consists of 2 parts
- Starting Easy Wireless Connect
- Download and run the setup files
1. Start Easy Wireless Connect on the printer.
Make sure that the printer is turned on.
If the power is on, the power lamp (A) will be lit.
-9?scl=1)
If the printer is performing any process, wait for the process to finish before starting setup.
Tap the HOME button (B) on the printer.
If an error screen is displayed, tap OK, then tap the HOME.
-6?scl=1)
Use the
buttons (C) to select
(D).
?scl=1)
Press OK.
Select LAN settings and tap OK.
Select Wireless LAN and tap OK.
Select Wireless LAN setup and tap OK.
Select Easy wireless connect and tap OK.
Select Yes and tap OK.
When the printer preparation is complete, the screen below appears.
Return to the setup application screen and proceed with the setup.
2. Download and run the setup file.
Click the link to Get the Setup File, once you identify the file compatible with your computer's operating system tap Download. After you download the files you can follow the instructions below to complete the setup process.
Start setup. Tap Next on the first screen.
Select Start Setup.
Select appropriate region and tap Next.
Select Yes on the License Agreement.
Select Agree or Do Not Agree to the Survey.
Status check occurs.
Select Yes on the Connection Method.
(Model #) used in example. Actual model series number will appear in the setup program.
Setup continues. If the Select wireless router screen (below) appears, select the wireless router to connect to the printer, enter the Network Key (password) and tap Next.
The router being used and its network settings determines whether or not this screen appears.
Network Connection completed. Tap Next.
The drivers will be downloaded and installed. This may take several minutes, depending on the speed of your internet connection.
Tap Add Printer on the Add Printer screen.
On the Add screen, select the TS series with Bonjour Multifunction listed in the Kind column. Select the Canon TS (Model #) series in the Use: dropdown list. Tap Add.
The Model # series varies by model, TS(Model #) series is used as an example only.
Tap Next on the Add Printer screen.
Tap Next.
Setup complete. Tap Next.
Select any optional application software desired. Tap Next.
Tap Next.
Tap Next or Skip.
Tap Exit.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
TS5020 Page
