Salesforce
Supported Media Types - TS8120
« Go Back
Information
TitleSupported Media Types - TS8120
URL NameART168203
Description
This article lists the types of media supported by the PIXMA TS8120.
Solution
For best results, choose paper designed for how you are printing. A variety of paper for documents as well as photos or illustrations is available from Canon. Use genuine Canon paper to print important photos, when possible.
Media Types
Genuine Canon paper
 Note
  • For warnings on use of the non-printable side, see each product's usage information.
  • For details on page sizes and media types, access the Canon website.
  • Genuine Canon paper is not available in some countries or regions. Note that in the United States, Canon paper is not sold by model number. Instead, purchase paper by name.
Paper for printing documents:
  • Canon Red Label Superior <WOP111>
  • Canon Océ Office Colour Paper <SAT213>
  • High Resolution Paper <HR-101N>*1
Paper for printing photos:
  • Photo Paper Pro Platinum <PT-101>
  • Glossy Photo Paper "Everyday Use" <GP-501>
  • Photo Paper Glossy <GP-701>
  • Photo Paper Plus Glossy II <PP-201>
  • Photo Paper Plus Glossy II <PP-301>
  • Photo Paper Pro Luster <LU-101>
  • Photo Paper Plus Semi-gloss <SG-201>
  • Matte Photo Paper <MP-101>
Paper other than genuine Canon paper
  • Plain Paper (including recycled paper)
  • Envelopes*1
  • T-Shirt Transfers*1
  • Greeting Card*1
*1 Printing to this paper from the operation panel or from a PictBridge (Wireless LAN) compliant device is not supported.
 Note
  • You can print onto a printable disc using the disc tray supplied with the printer.
  • When printing photos saved on a PictBridge (Wireless LAN) compliant device, you must specify the page size and media type.
  • You can use non-Canon genuine art paper. For details, access our website.
    You cannot print in the top and bottom 1.38 inch (35 mm) margins of the paper (in the printing direction).
Page Sizes
You can use the following page sizes.
 Note
  • Page sizes and media types the printer supports differ depending on the OS you are using.
Standard sizes:
  • Letter
  • Legal
  • A4
  • B5
  • A5
  • L(89x127mm)
  • KG/4"x6"(10x15)
  • 2L/5"x7"(13x18)
  • Square 5"x5" 127x127mm
  • Hagaki
  • Hagaki 2
  • Card 2.17"x3.58" 55x91mm
  • 8"x10"(20x25cm)
  • Envelope Com 10
  • Envelope DL
  • Nagagata 3
  • Nagagata 4
  • Yougata 4
  • Yougata 6
Special sizes
Special page sizes must be within the following limits:
  • rear tray
    - Minimum size: 2.17 x 3.51 inches (55.0 x 89.0 mm)
    - Maximum size: 8.50 x 26.61 inches (215.9 x 676.0 mm)
  • cassette
    - Minimum size: 5.83 x 8.27 inches (148.0 x 210.0 mm)
    - Maximum size: 8.50 x 11.69 inches (215.9 x 297.0 mm)
Paper Weight
You can use paper in the following weight range.
  • 17 to 28 lb (64 to 105 g /m2) (plain paper other than genuine Canon paper)
TS8120 Page
Powered by
