Get the setup file.
Setup can also be performed by using the Setup CD.
Read the information carefully and take note of how to run the setup file if it doesn't start automatically.
If you see a message like this:
Select OK. Then, control-click on the setup file, select Open, then select Open in the error message window. This will allow the setup program to proceed.
Select Download.
Select Next on the first screen.
Enter your computer User Name and Password, then select Install Helper.
Select Start Setup.
Select the appropriate region and country, then Next.
Select Yes to the License Agreement to continue the setup process.
Select Agree or Do not agree to the survey.
A status check occurs. Wait for the process to finish.
Select Yes on the Connection Method screen.
Setup continues. If the Select wireless router screen (below) appears, select the wireless router to connect to the printer, enter the Network Key (password) and select Next.
This screen may not appear, depending on your router and network settings.
When the network connection is completed, select Next.
The drivers will now be installed. Wait for this to finish.
If the following screen appears, select Allow.
Select Add Printer on the Add Printer screen.
On the Add screen, select the TS series with Bonjour Multifunction listed in the Kind column. Select AirPrint or Secure AirPrint in the Use: dropdown list.
Select Next on the Add Printer screen.
Select Execute if you want to run a test print. If not, select Next to continue.
When you see the Setup Complete screen, select Next. You are almost finished.
Select any optional software applications you want to add, then select Next.
On the You Can Print... screen, select Next.
Select Skip or Next on the User Registration screen.
Select Exit. The installation is complete. You are ready to print or scan wirelessly.
