To print or scan wirelessly on a Windows computer, the printer must first be connected to the wireless network and software drivers and applications installed. Please follow the instructions below
Start Easy Wireless Connect on the printer first before you set up the computer.
If the printer is in the process of cleaning, print head alignment, etc., wait for the process to finish before you start the setup.
Notes on Wireless Connection.
Set up Easy Wireless Connect on the printer.
Make sure the printer is turned on.
If the power is on, the power lamp (A) will be lit.
-9?scl=1)
Press the Home button (B) on the printer.
If an error screen is displayed, press OK button, then press the Home button.
-6?scl=1)
Use the up
, down
, left
, or right
arrow buttons (C) to select the wireless icon
(D).
?scl=1)
Press the OK button.
Select LAN settings and press the OK button.
-7?scl=1)
Select Wireless LAN and press the OK button.
-3?scl=1)
Select Wireless LAN setup and press the OK button.
Select Easy wireless connect and press the OK button.
-31?scl=1)
Select Yes and press the OK button.
-23?scl=1)
When the printer preparation is complete, the screen below appears. Return to the setup application screen and proceed with the setup.
-19?scl=1)
Windows software and driver set up.
Download and run the setup file.
Read the information carefully. Take note how to run the setup file if setup does not start automatically.
Select Start Setup.
Select your place of residence, and select Next.
Select Yes on the License Agreement screen.
The Extended Survey Program screen will appear. Select Agree or Do Not Agree. You can still use the software if you select Do Not Agree.
Select Next.
Select Yes on the Connection Method screen.
If the 'Select wireless router' screen appears, select your wireless router, enter the Network Key or password, and select Next.
The router's network settings determines whether or not this screen appears
Setup continues. This may take a few moments.
Network Connection is completed. Select Next.
Print head alignment and test print screens appear next. These can be performed or not. If you choose to perform these, carefully follow the on-screen instructions.
Setup is complete. Select Next.
Place a check in the box next to the optional application software that you would like to install, then select Next.
Select Next.
Select Next or Skip.
Select Exit.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
