Salesforce
Print Settings - TS8120
« Go Back
Information
TitlePrint Settings - TS8120
URL NameART168229
Description
Solution
**To change print settings, first access the machine's Device Settings.
Available Print Settings:
  • Prevent paper abrasion
    Use this setting only if the print surface becomes smudged.
     Important
    • Be sure to set this back to OFF after printing since it may result in lower printing speed or lower print quality.
  • Extended copy amount
    Selects the amount of image that extends off the paper when printing in borderless (full).
    Slight cropping may occur at the edges since the copied image is enlarged to fill the whole page. You can change the width to be cropped from the borders of the original image as needed.
     Important
    • This setting can be applied under the following conditions:
      - Performing borderless copying
      - Borderless is selected for Border when copying printed photos
     Note
    • If printouts contain margins even though you are printing in Borderless, specifying Extended amount: Large for this setting may help solve the problem.
  • Adjust disc print area
    You can adjust the disc printing area if the image is not aligned with the printable disc.
    You can adjust the printing area in increments of 0.003 inches/0.1 mm between -0.03 inches/-0.9 mm and +0.03 inches/+0.9 mm.
  • Auto photo fix setting
    When ON is selected, you can select whether to print photos using the Exif information recorded in the image files in the following cases.
    • Auto photo fix is selected for Photo fix when printing from a memory card.
    • The print setting on the PictBridge (Wireless LAN) compliant device is set to Default* or On when printing with a PictBridge (Wireless LAN) compliant device.
      * When Default is selected for the print setting on the PictBridge (Wireless LAN) compliant device, select Auto photo fix for Photo fix in PictBridge print settings.
  • Adjust horizontal print position
    Adjusts the print position when the left/right margins are not aligned.
    You can adjust the left/right margins in increments of 0.01 inch/0.1 mm between -0.12 inch/-3 mm and +0.12 inch/+3 mm centered on the horizontal center of the paper.
     Important
    • For Letter-sized or Legal-sized paper, you can adjust the left/right margins between -0.06 inch/-1.5 mm and +0.06 inch/+1.5 mm even if you specify the value over 0.06 inch/1.5 mm.
TS8120 Page
Powered by
