Solution | Platen GlassItem | Details |
Types of originals | - Text document, magazine, or newspaper - Printed photo, postcard, business card, or disc (BD/DVD/CD, etc.) - Documents that are not suitable for the ADF | Size (width x height) | Max. 8.5 x 11.7 inches (216 x 297 mm) | Quantity | One or more sheets depending on the size of the items | Thickness | Max. 0.4 inch (10 mm) |
In the ADF (Auto Document Feeder)Item | Details |
Kind of original | Plain-paper documents with multiple pages of the same size, thickness, and weight | Size | A4, Letter, Legal Duplex copying or 2-on-1/4-on-1 copying: A4/Letter only | Quantity | - A4/Letter: Max. 20 sheets (20 lb. (75 g /m2) paper), up to 0.08 inch (2 mm) high - Legal: Max. 5 sheets (20 lb. (75 g /m2) paper), up to 0.02 inch (0.5 mm) high | Thickness | 0.003 to 0.005 inch (0.07 to 0.13 mm) | Weight | 16.0 to 25.3 lb. (60 to 95 g /m2) |
Note
Make sure any liquids on documents, such as glue, ink, or correction fluid are dry before loading. Do not load glued documents in the ADF, even if the glue is dry, because this may cause paper jams. - Remove all staples, paper clips, or other fasteners before feeding documents.
- Load Legal-sized documents in the ADF.
Do not load these kinds of documents in the ADF, which may cause paper jams. - Wrinkled or creased documents
- Curled documents
- Torn documents
- Documents with holes
- Glued documents
- Documents with sticky notes
- Documents on carbon paper
- Documents on coated paper
- Documents on onion skin or other thin paper
- Photos or excessively thick documents
TR8520 Page |
