Note: The steps listed below are specific to the MG5420. For instructions for other models, click here
You can print out the network settings of the machine such as its IP address and SSID.
Important
This print out contains valuable information about your computer. Handle it with care.
Make sure that the machine is turned on.
Load a sheet of A4 or Letter-sized plain paper.
Select Setup on the HOME screen.
The menu screen is displayed.
Select Device settings, then use the OK button to confirm the selection.
Use the button to select LAN settings, then use the OK button to confirm the selection.
Use the button to select Confirm LAN settings, then use the OK button to confirm the selection.
Use the button to select Print LAN details, then use the OK button to confirm the selection.
Use the button to select Yes, then use the OK button to start printing.
The machine starts printing the network setting information.
The following information on the machine's network setting is printed out.
Item
Explanations of the item
Setting
Wireless LAN
Enable/Disable
Connection
Status of the Wireless LAN
Active/Inactive
MAC Address
XX:XX:XX:XX:XX:XX
SSID
SSID of the wireless LAN
Communication Mode
Infrastructure
Channel
XX (1 to 13)
Encryption
Method of the Encryption
none/WEP/TKIP/AES
WEP Key Length
Inactive/128/64
Authentication
Method of the Authentication
none/auto/open/shared/WPA-PSK/WPA2-PSK
Signal Strength
0 to 100 [%]
TCP/IP Version
IPv4 & IPv6/IPv4
IPv4 IP Address
Selected IP Address (IPv4)
XXX.XXX.XXX.XXX
IPv4 Default Gateway
Default Gateway (IPv4)
Subnet Mask
IPv6 IP Address *1
Selected IP Address (IPv6)
XXXX:XXXX:XXXX:XXXX XXXX:XXXX:XXXX:XXXX
IPv6 Default Gateway *1
Default Gateway (IPv6)
Subnet Prefix Length*1
XXX
IPsec*2
IPsec setting
Active
Security Protocol*2
Method of the Security Protocol
ESP/ESP & AH/AH
Wireless LAN DRX
Discontinuous reception (wireless LAN)
Other Settings
Other settings
Printer Name
Printer name
Printer name (Up to 15 characters)
Shared Memory Card
Memory card sharing
WSD
WSD setting
WSD Timeout
Timeout
1/5/10/15/20 [min]
LPR Protocol
LPR protocol setting
Bonjour
Bonjour setting
Bonjour Service Name
Bonjour service name
Bonjour service name (Up to 52 characters)
PictBridge Commun.
PictBridge Communication
DNS Server
Getting DNS Server automatically
Auto/Manual
Primary Server
Primary server address
Secondary Server
Secondary server address
Proxy Server
Proxy Server setting
Proxy Port
Specifying Proxy Port
1 to 65535
Proxy Address
XXXXXXXXXXXXXXXXXXXX
IP Address Filtering
("XX" represents alphanumeric characters.)
*1 Only when IPv6 is activated, the status of the network is printed.
*2 Only IPv6 and the IPsec setting are activated, the status of the network is printed.
