Salesforce
Printing Photographs Directly from a PictBridge (Wi-Fi) Compliant Device - PRO-200
« Go Back
Information
TitlePrinting Photographs Directly from a PictBridge (Wi-Fi) Compliant Device - PRO-200
URL NameART177834
Description
Learn about printing images with the PIXMA PRO-200 from a wireless PictBridge device.
Solution
You can connect a PictBridge (Wi-Fi) compliant device such as a digital still camera, digital camcorder, or camera-equipped mobile phone to the printer via Wi-Fi, and print recorded images directly without using a computer.
Connectable devices:
Printable image data format:
The printer accepts images* taken with a camera compliant with the Design rule for Camera File system and PNG files.
* Exif 2.2/2.21/2.3 compliant
 A wi-fi connection with the printer is required to use this function.
 PictBridge is the Standard to print your photos directly without using a computer, connecting a device such as a digital still camera, digital camcorder, or camera-equipped mobile phone.
 When printing photos with the PictBridge (Wi-Fi) compliant device connected to the printer, we recommend the use of the AC adapter supplied with the device. If you are using the device battery, be sure to charge it fully.
 Depending on the model or brand of your device, you may have to select a print mode compliant with PictBridge (Wi-Fi) before connecting the device. You may also have to turn on the device or select Play mode manually after connecting the device to the printer.
Perform necessary operations on the PictBridge (Wi-Fi) compliant device before connecting it to this printer according to instructions given in the device's instruction manual.
  1. Make sure that the printer is powered on.
  2. Load paper into the top feed or the manual feed tray.
  3. Detect the printer with the PictBridge (Wi-Fi) compliant device and connect the PictBridge (Wi-Fi) compliant device to the printer.
     For more on detecting the printer, refer to your PictBridge (Wi-Fi) compliant device's instruction manual.
  4. Use your PictBridge (Wi-Fi) compliant device to select the same size and type of paper as is loaded in the printer.
    If your PictBridge (Wi-Fi) compliant device does not have a setting menu, change the setting from the printer.
     When printing from the PictBridge (Wi-Fi) compliant device, set the print quality with the operation panel on the printer. You cannot set the print quality on the PictBridge (Wi-Fi) compliant device.
  5. Start printing from your PictBridge (Wi-Fi) compliant device.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
