Salesforce
PIXMA TR4720 Easy Wireless Connect Setup - Windows
« Go Back
Information
TitlePIXMA TR4720 Easy Wireless Connect Setup - Windows
URL NameART180290
Description
Use Easy wireless connect to establish the printer's wireless connection to your network.
Solution
Wireless Setup - Windows** Computers
Video:
Written Instructions:
**Instructions in this article are for setup on a Windows computer.  If setting up on a Mac, click here for instructions
To be able to use your printer to print or scan wirelessly on a Windows computer, the printer must first be connected to the wireless network. Then, drivers and software need to be installed on the computer.  The instructions / screenshots below show the setup program steps when using the Easy wireless connect method to connect to the wireless network.
The setup process consists of 2 parts:
  1. Starting Easy wireless connect on the printer, and
  2. Downloading and running the setup file to install the drivers and software.
Start Easy wireless connect on the printer
Prior to starting setup on the computer, start Easy wireless connect on the printer. Then complete the setup on the computer.
See the procedure below to start Easy wireless connect.
  1. With the printer powered on, press and hold the   Menu / Wireless connect button until Processing... appears. Release the button.
    Figure: LCD
    The printer is now waiting to receive wireless network information from your computer.
Download and run the setup file.*
Get the Setup File
 The Setup File can also be obtained from the Canon USA website. Select Master Setup from the list, then click the Download button.
  1. Choose your language, then click OK.
    Choose your language, then click OK (outlined in red)
  2. Choose your place of residence, then click OK.
    Choose your place of residence, then click OK (outlined in red)
  3. Click Start Setup.
    Click Start Setup (outlined in red) to proceed
    The installer will acquire information on the latest driver and software for your printer. This may take several minutes.
    It may take a few minutes for the installer to acquire information on the latest driver and software for the printer
  1. Read the license agreement. Select Yes to proceed.  If you click No, the installation will not proceed.
    Click Yes (outlined in red) to proceed
  2. Select Agree or Do Not Agree to the information request.
    Click Agree or Do not agree (outlined in red)
    This message appears if you selected Do not agree. Click OK to proceed.
    Click OK (outlined in red) to proceed
    The installer will process for a few moments. Please wait.
    Processing...
  3. Click Next.
    Click Next (outlined in red)
    The installer will search for the printer. This may take a few moments.
    Please wait
  4. Make sure that the name of your network is shown in the following window. Click Connect to proceed.
    Click Connect (outlined in red) to proceed
    The computer's wireless network connection will be temporarily disabled. Please wait.
    The computer's wireless network connection is temporarily disabled
    After the connection has been completed, the installer will download and install the MP Drivers. This may take several minutes.
    Installing MP Drivers
     If your printer is not detected, make sure that the computer has reconnected to the correct network. Also, you may need to temporarily disable any firewall software, or you may need to open blocked ports in the firewall. If your PC is connected to a VPN (Virtual Private Network), temporarily disconnect from the VPN and try the setup again. Also, if you are using a dual-band router, further troubleshooting information can be found here.
     The IJ Scan Utility will be installed along with the MP Drivers.
  5. After processing for a few moments, the installation will be complete. Click Next to proceed. If desired, you can click Test Print to print a test page.
    Click Next (outlined in red) to proceed)
  6. Click Go to Website to open a web browser, which will take you to the Canon website to download additional software for your printer.
    Click Go to Website (outlined in red)
Powered by
