If you have set up a wireless printer to work with Canon PRINT but want to add another one, follow the steps below.
These instructions assume that the printer you want to add is already connected to the wireless network. Also, please make sure that the printer you wish to add to the list is powered on.
On the main screen, tap the Add/Switch icon.
On the Registered Printers screen, tap Register Printer.
On the Register Printer screen, wait for the printer you wish to add to appear in the list. When it appears, tap it.
After a few moments, the app will return to the main screen. Tap Close when the message appears.
When this screen appears, tap Select Images if you want to print a picture, or tap the X at the upper right.
You may see a prompt similar to the following.
If you want this app to save your network name and password to make it easier to reconnect this printer, or to add a new one, make sure the Save box is checked, then tap OK.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
