Salesforce
Print the Network Settings (LAN Details) - TS7720
« Go Back
Information
TitlePrint the Network Settings (LAN Details) - TS7720
URL NameART184312
Description
This article shows how to print the network setting information (LAN details) of the PIXMA TS7720.
An example of this information is attached to this article.
Solution
Use the operation panel to print the printer's current network settings.
 The network settings printout contains important information about your network. Handle it with care.
  1. Make sure the printer is powered on.
  2. Load four or more sheets of A4 or Letter-sized plain paper in the cassette or the rear tray.
  3. Select Setup icon (gear) (Setup) on HOME screen.
  4. Select Printer settings.
  5. Select LAN settings.
  6. Select Print details.
  7. Check the displayed message and select Yes.
  8. When the confirmation screen for printing passwords appears, select ON or OFF.
    The printer starts printing the network setting information.
The following information on the printer's network setting is printed out. (Some setting values are not displayed depending on the printer settings.)
Item Number
Item
Description
Setting
1
Product Information
Product information
1-1
Product Name
Product name
XXXXXXXX
1-2
ROM Version
ROM version
XXXXXXXX
1-3
Serial Number
Serial number
XXXXXXXX
1-4
Default Password
Default password (for accessing Remote UI)
XXXXXXXX
2
Network Diagnostics
Network diagnostics
2-1
Diagnostic Result
Diagnostic result
XXXXXXXX
2-2
Result Codes
Result codes
XXXXXXXX
2-3
Result Code Details
Result code details
Information on the codes in this section can be found here.
3
Wireless LAN
Wireless LAN
Enable / Disable
3-2
Infrastructure
Infrastructure
Enable / Disable
3-2-1
Signal Strength
Signal strength
0 to 100 [%]
3-2-2
Link Quality
Link quality
0 to 100 [%]
3-2-3
Frequency
Frequency
2.4 / 5 [GHz]
3-2-4
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
3-2-5
Connection
Connection status
Active / Inactive
3-2-6
SSID
SSID
Wireless LAN network name (SSID)
3-2-7
Channel
Channel
XXX (1 to 13, 36, 40, 44, 48, 52, 56, 60, 64, 100, 104, 108, 112, 116, 120, 124, 128, 132, 136, 140, 149, 153, 157, 161, 165)
3-2-8
Encryption
Encryption method
none / TKIP / AES
3-2-10
Authentication
Authentication method
none / auto / open / shared / WPA-PSK / WPA2-PSK / WPA3-SAE / WPA-EAP / WPA2-EAP / WPA3-EAP
3-2-11
TCP / IPv4
TCP / IPv4
Enable
3-2-12
IP Address
IP address
XXX.XXX.XXX.XXX
3-2-13
Subnet Mask
Subnet mask
XXX.XXX.XXX.XXX
3-2-14
Default Gateway
Default gateway
XXX.XXX.XXX.XXX
3-2-15
TCP / IPv6
TCP / IPv6
Enable / Disable
3-2-16
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-17
Link Local Prefix Length
Link local prefix length
XXX
3-2-18
Stateless Address1
Stateless address 1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-19
Stateless Prefix Length1
Stateless prefix length 1
XXX
3-2-20
Stateless Address2
Stateless address 2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-21
Stateless Prefix Length2
Stateless prefix length 2
XXX
3-2-22
Stateless Address3
Stateless address 3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-23
Stateless Prefix Length3
Stateless prefix length 3
XXX
3-2-24
Stateless Address4
Stateless address 4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-25
Stateless Prefix Length4
Stateless prefix length 4
XXX
3-2-26
Default Gateway1
Default gateway 1
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-27
Default Gateway2
Default gateway 2
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-28
Default Gateway3
Default gateway 3
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-29
Default Gateway4
Default gateway 4
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-2-33
IPsec
IPsec setting
Active / Inactive
3-2-34
Security Protocol
Security method
ESP / ESP & AH / AH / Blank (Not selected)
3-2-35
Wireless LAN DRX
Discontinuous reception (wireless LAN)
Enable / Disable
3-3
Wireless Direct / Access Point Mode
Operation mode for Wireless Direct
Enable / Disable
3-3-1
MAC Address
MAC address
XX:XX:XX:XX:XX:XX
3-3-2
Connection
Connection status
Active / Inactive
3-3-3
SSID
SSID
Wireless Direct network name (SSID)
3-3-4
Password
Password
Wireless Direct password
3-3-5
Channel
Channel
3,6,36,40
3-3-6
Encryption
Encryption method
AES
3-3-7
Authentication
WPA2-PSK
3-3-8
TCP / IPv4
TCP / IPv4
Enable
3-3-9
IP Address
IP address
XXX.XXX.XXX.XXX
3-3-10
Subnet Mask
Subnet mask
XXX.XXX.XXX.XXX
3-3-11
Default Gateway
Default gateway
XXX.XXX.XXX.XXX
3-3-12
TCP / IPv6
TCP / IPv6
Enable / Disable
3-3-13
Link Local Address
Link local address
XXXX:XXXX:XXXX:XXXX
XXXX:XXXX:XXXX:XXXX
3-3-14
XXX
3-3-15
IPsec
IPsec setting
Active / Inactive
3-3-16
Security Protocol
Security method
3-3-17
Wireless LAN DRX
Discontinuous reception (wireless direct)
Disable
3-3-18
Frequency
Wireless Direct frequency
2.4 / 5 [GHz]
5
Other Settings
Other settings
5-1
Printer Name
Printer name
Printer name
5-2
Wireless Direct DevName
Device name for wireless direct
5-4
WSD Printing
WSD printing setting
Enable / Disable
5-5
WSD Timeout
Timeout
1 / 5 / 10 / 15 / 20 [min]
5-6
LPD Printing
LPD printing setting
Enable / Disable
5-7
RAW Printing
RAW printing setting
Enable / Disable
5-9
Bonjour
Bonjour setting
Enable / Disable
5-10
Bonjour Service Name
Bonjour service name
5-11
LLMNR
LLMNR setting
Enable / Disable
5-12
SNMP
SNMP setting
Enable / Disable
5-14
DNS Server
Obtain DNS server address automatically
Auto / Manual
5-15
Primary Server
Primary server address
XXX.XXX.XXX.XXX
5-16
Secondary Server
Secondary server address
XXX.XXX.XXX.XXX
5-17
Proxy Server
Proxy server setting
Enable / Disable
5-18
Proxy Address
Proxy address
XXXXXXXXXXXXXXXXXXXX
5-19
Proxy Port
Proxy port specification
1 to 65535
5-20
Cert. Fingerprt(SHA-1)
Certificate fingerprint(SHA-1)
xxxxxxxx xxxxxxxx xxxxxxxx
xxxxxxxx xxxxxxxx
5-21
Cert. Fingerprt(SHA-256)
Certificate fingerprint(SHA-256)
xxxxxxxx xxxxxxxx xxxxxxxx xxxxxxxx
7
Web Services
Web Services
7-1
Unsent Usage Logs
Number of unsent usage logs
0 to 200
7-2
Usage Log Last Sent
Last date when usage log was sent
XXXXXXXX
7-3
Web Service Status
Registration status
Not set / Disabled / Registration pending / Registered
7-4
Log Transmission Status
Transmission result
Not activated / Processing / Server error / Connection error / Timeout error / Error / Awaiting server response / Active
7-5
Subscription Information
Subscription information
7-5-1
Subscription Status
Subscription status
Not Available / Active / Inactive
7-5-2
Remaining Offline Prints
Number of remaining pages that can be printed offline
xxx
7-5-3
Installed Cartridge Type
Cartridge type for subscription
Subscription / Setup / Normal
7-5-4
Online Support
Online support for subscription URL
xxxxxxxxxxxxxxxx (54 characters)
9
Security policy
Security policy status
9-1
Security administrator password
Enable / Disable
9-2
Interface
Interface function
9-2-1
Wi-Fi policy
Wireless connection policy
Prohibit use of direct connection
Enable / Disable
Prohibit use of wireless LAN (Wi-Fi)
Enable / Disable
9-2-2
USB policy
USB connection policy
Prohibit use of USB connection
Prohibit use of USB device
Enable / Disable
Prohibit use of external USB devices
Prohibit use as USB storage device
Enable / Disable
9-3
Network
Network function
9-3-1
Communication policy
Communication operational policy
Always verify signatures for SMB / WebDAV server functions
Always verify signatures when using SMB / WebDAV server functions
Enable / Disable
Always verify server certificate when using TLS
Enable / Disable
Prohibit cleartext authentication for server functions
Enable / Disable
Prohibit use of SNMPv1
Enable / Disable
9-3-2
Port usage policy
Port Usage Policy
Restrict LPD port
Restrict LPD port
Enable / Disable
Restrict RAW port
Restrict RAW port
Enable / Disable
Restrict FTP port
Restrict FTP port
Enable / Disable
Restrict WSD port
Restrict WSD port
Enable / Disable
Restrict BMLinkS port
Enable / Disable
Restrict IPP port
Restrict IPP port
Enable / Disable
Restrict SMB port
Restrict SMB port
Enable / Disable
Restrict SMTP port
Restrict SMTP port
Enable / Disable
Restrict dedicated port
Enable / Disable
Restrict remote operation's software port
Enable / Disable
Restrict SIP (IP Fax) port
Enable / Disable
Restrict mDNS port
Restrict mDNS port
Enable / Disable
Restrict SLP port
Restrict SLP port
Enable / Disable
Restrict SNMP port
Restrict SNMP port
Enable / Disable
9-4
Authentication
Authentication function
9-4-1
Authentication policy
Authentication operational policy
Prohibit guest users from using the printer
Prohibit guest users from using the device
Enable / Disable
Force auto logout
Force auto logout
Enable / Disable
Logout period
Time Until Logout
xx sec
9-4-2
Pwd operation policy
Password operational policy
Prohibit caching of password for external servers
Enable / Disable
Display warning when default password is in use
Enable / Disable
Prohibit use of default password for remote access
Enable / Disable
9-4-3
Password settings policy
Minimum number of characters for password
Set minimum number of characters for password
Enable / Disable
characters (1 - 32)
1~32 (characters)
Password validity period
Set password validity period
Enable / Disable
days (1 - 180)
Validity period for password
1-180 days
Prohibit use of 3 or more identical consecutive characters
Enable / Disable
Require use of at least 1 uppercase character
Force use of at least 1 uppercase character
Enable / Disable
Require use of at least 1 lowercase character
Force use of at least 1 lowercase character
Enable / Disable
Require use of at least 1 number
Force use of at least 1 digit
Enable / Disable
Require use of at least 1 symbol
Force use of at least 1 symbol
Enable / Disable
9-4-4
Lockout policy
Lockout Policy
Enable lockout
Enable lockout
Enable / Disable
Lockout threshold (times)
Lockout Threshold
1-10 time
Lockout period (minutes)
Lockout Period
1-60 min
9-5
Key / Certificate
Key / Certificate function
Prohibit use of weak encryption
Enable / Disable
Prohibit use of key / certificates with weak encryption
Prohibit use of key / certificate with weak encryption
Enable / Disable
Use TPM to store password and key
Enable / Disable
9-6
Log
Log function
Force recording of audit log
Enable / Disable
Require SNTP settings
Force SNTP settings
Enable / Disable
Server name
SNTP server name setting
URL
9-7
Job
Job function
9-7-1
Printing policy
Printing Policy
Prohibit immediate printing of received jobs
Enable / Disable
9-7-2
Send / Receive policy
Sending / Receiving Policy
Allow sending only to registered addresses
Enable / Disable
Force confirmation of fax number
Enable / Disable
Prohibit auto forwarding
Enable / Disable
9-7-3
Storage
Storage policy
Force complete deletion of data
Enable / Disable
("XX" represents alphanumeric characters.)
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
