Salesforce
Cleaning the Print Head - MX532
« Go Back
Information
TitleCleaning the Print Head - MX532
URL NameART114379
Description
This article shows how to clean the print head of the PIXMA MX532 from its operation panel.
Solution
Clean the print head if lines are missing or if horizontal white streaks are present in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Cleaning the print head consumes ink, so clean the print head only when necessary.
  1. Make sure that the power is turned on.
  2. Clean the print head.
    1. Press the Setup button.
      The Setup menu screen will appear.
    2. Use the Left or Right button to select Maintenance, then press the OK button.
    3. Use the Left or Right button to select Cleaning, then press the OK button.
      Figure: LCD
      The machine starts cleaning the print head.
      Do not perform any other operations until the machine completes the cleaning of the print head. This takes about 1 to 2 minutes.
  3. Print the nozzle check pattern to check the print head condition .
If the problem is not resolved after cleaning the print head twice, clean the print head deeply .
For support and service options, sign into (or create) your Canon Account from the link below.
My Canon Account
Powered by
