Salesforce
Printing Out Network Setting Information - MG5620
« Go Back
Information
TitlePrinting Out Network Setting Information - MG5620
URL NameART116995
Description
This article explains how to print a Network Configuration Page for the PIXMA MG5620.  An example of this page is attached to this article.
Solution
You can print out the current network settings of the machine using the operation panel of the machine.
 The steps listed below are specific to the MG5620. For instructions for other models, click here.
 This print out contains valuable information about your computer. Handle it with care.
  1. Make sure that the printer is powered on.
  2. Load a sheet of A4 or Letter-sized plain paper.
  3. Select Setup on the HOME screen.
    The menu screen is displayed.
  4. Select Device settings, then press the OK button.
  5. Use the UP DOWN button to select LAN settings, then press the OK button.
  6. Use the UP DOWN button to select Confirm LAN settings, then then press the OK button.
  7. Use the UP DOWN button to select Print LAN details, then press the OK button.
  8. Use the UP DOWN button to select Yes, then press the OK button to start printing.
    The machine starts printing the network setting information.
    The following information on the machine's network setting is printed out.
    Item
    Explanations of the item
    Setting
    Wireless LAN
    Wireless LAN
    Enable/Disable
    Connection
    Connection status
    Active/Inactive
    MAC Address
    MAC Address
    XX:XX:XX:XX:XX:XX
    SSID
    SSID
    SSID of the wireless LAN/SSID of the access point mode
    Password
    Password
    Password of the access point mode (8 to 10 alphanumeric characters)
    Communication Mode
    Communication Mode
    Infrastructure/Access Point Mode
    Channel *1
    Channel
    XX (1 to 13)
    Encryption
    Method of the Encryption
    none/WEP/TKIP/AES
    WEP Key Length
    WEP Key Length
    Inactive/128/64
    Authentication
    Method of the Authentication
    none/auto/open/shared/WPA-PSK/WPA2-PSK
    Signal Strength
    Signal Strength
    0 to 100 [%]
    TCP/IP Version
    TCP/IP Version
    IPv4 & IPv6/IPv4
    IPv4 IP Address
    Selected IP Address (IPv4)
    XXX.XXX.XXX.XXX
    IPv4 Default Gateway
    Default Gateway (IPv4)
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet Mask
    XXX.XXX.XXX.XXX
    IPv6 IP Address *2
    Selected IP Address (IPv6)
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    IPv6 Default Gateway *2
    Default Gateway (IPv6)
    XXXX:XXXX:XXXX:XXXX
    XXXX:XXXX:XXXX:XXXX
    Subnet Prefix Length *2
    XXX
    IPsec *3
    IPsec setting
    Active
    Security Protocol *3
    Method of the Security Protocol
    ESP/ESP & AH/AH
    Wireless LAN DRX
    Discontinuous reception (wireless LAN)
    Enable/Disable
    Other Settings
    Other settings
    Printer Name
    Printer name
    Printer name (Up to 15 alphanumeric characters)
    WSD
    WSD setting
    Enable/Disable
    WSD Timeout
    Timeout
    1/5/10/15/20 [min]
    LPR Protocol
    LPR protocol setting
    Enable/Disable
    Bonjour
    Bonjour setting
    Enable/Disable
    Bonjour Service Name
    Bonjour service name
    Bonjour service name (Up to 52 alphanumeric characters)
    PictBridge Commun.
    PictBridge Communication
    Enable/Disable
    DNS Server
    Getting DNS Server automatically
    Auto/Manual
    Primary Server
    Primary server address
    XXX.XXX.XXX.XXX
    Secondary Server
    Secondary server address
    XXX.XXX.XXX.XXX
    Proxy Server
    Proxy Server setting
    Enable/Disable
    Proxy Port
    Specifying Proxy Port
    1 to 65535
    Proxy Address
    Proxy Address
    XXXXXXXXXXXXXXXXXXXX
    ("XX" represents alphanumeric characters.)
    *1 Depending on the country or region of purchase, one of the channels from 1 to 11 is printed.
    *2 Only when IPv6 is enabled, the status of the network is printed.
    *3 Only IPv6 and the IPsec setting are enabled, the status of the network is printed.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
