Salesforce
Scanning with Favorite Settings using IJ Scan Utility
« Go Back
Information
TitleScanning with Favorite Settings using IJ Scan Utility
URL NameART137704
Description
Solution
You can scan items placed on the platen with your favorite settings saved beforehand.
This is convenient for saving frequently used settings or when specifying scan settings in detail.
  1. Start IJ Scan Utility.
    Starting IJ Scan Utility
  2. Click Settings..., select the Settings (Custom Scan) dialog box, then set the item type, resolution, etc.
    Settings (Custom Scan) Dialog Box
    When setting is completed, click OK.
    Note:
    • Once the settings are made, you can scan with the same settings from the next time.
  3. Place the item on the platen.
    Placing Items (When Scanning from a Computer)
  4. Click Custom.
    figure: IJ Scan Utility
    Scanning starts.
Note:
  • Click Cancel to cancel the scan.
  • Scanned images are saved in the folder set for Save in in the Settings (Custom Scan) dialog box displayed by clicking Settings.... In the Settings (Custom Scan) dialog box, you can also make advanced scan settings.
Powered by
