Solution | Click Custom Scan on the
(Scanning from a Computer) tab to display the Settings (Custom Scan) dialog box. In the Settings (Custom Scan) dialog box, you can make advanced scan settings to scan according to your preference.
Note: The scanning from the operation panel
tab is not displayed for all models. (1) Scan Options Area (2) Save Settings Area (3) Application Settings Area
Important (1) Scan Options Area-
Select Source Select the type of item to be scanned. When Auto is selected, the item type is automatically detected. Color Mode, Paper Size and Resolution are automatically set as well.
Important -
Item types supported by Auto are photos, postcards, business cards, magazines, newspapers, documents, and BD/DVD/CD. -
To scan the following types of items, specify the item type or size. You cannot scan correctly with Auto. - A4 size photos - Text documents smaller than 2L (5 inches x 7 inches) (127 mm x 178 mm), such as paperback pages with the spine cut off - Items printed on thin white paper - Long narrow items such as panoramic photos -
Reflective disc labels may not be scanned as expected. -
Place items correctly according to the type of item to be scanned. Otherwise, items may not be scanned correctly. See "Placing Items (When Scanning from a Computer)" for details on how to place items. -
To convert text in the image into text data after scanning, specify Select Source instead of selecting Auto.
Note -
Color Mode Select how to scan the item.
Important -
Paper Size Select the size of the item to be scanned. When you select Custom, a screen in which you can specify the item size appears. Select a Unit, then enter the Width and Height, and then click OK.
Note -
Resolution Select the resolution of the item to be scanned. The higher the resolution (value), the more detail in your image.
Resolution
Note -
Compress scanned images upon transfer Compresses scanned images when transferring them to a computer. This is useful when your scanner or printer and computer are connected with a slow interface such as USB1.1 or a network.
Important -
Image Processing Settings Click
(Plus) to set the following. Available setting items vary by Select Source. When Select Source is Photo
Note When Select Source is Magazine or Document
Note -
Apply Auto Document Fix Select this checkbox to sharpen text in a document or magazine for better readability.
Important -
Available only when the Compress scanned images upon transfer checkbox is not selected. -
The color tone may differ from the source image due to corrections. In that case, deselect the checkbox and scan.
Note -
Sharpen outline Emphasizes the outline of the subjects to sharpen the image. -
Reduce show-through Sharpens text in an item or reduces show-through in newspapers, etc. -
Reduce moire Reduces moire patterns. Printed materials are displayed as a collection of fine dots. "Moire" is a phenomenon where uneven gradation or a stripe pattern appears when such photos or pictures printed with fine dots are scanned.
Note -
Reduce gutter shadow Reduces gutter shadows that appear between pages when scanning open booklets.
Important
Note -
Correct slanted text document Detects the scanned text and corrects the angle (within -0.1 to -10 degrees or +0.1 to +10 degrees) of the document.
Important -
The following types of documents may not be corrected properly since the text cannot be detected correctly. - Documents in which the text lines are inclined more than 10 degrees or the angles vary by line - Documents containing vertical and horizontal text - Documents with extremely large or small fonts - Documents with small amount of text - Documents containing figures/images - Hand-written text - Documents containing vertical and horizontal lines (tables)
Note -
Detect the orientation of text document and rotate image Automatically rotates the image to the correct orientation by detecting the orientation of text in the scanned document.
Important -
Only text documents written in languages that can be selected from Document Language in the Settings (General Settings) dialog box are supported.
Settings (General Settings) Dialog Box -
The orientation may not be detected for the following types of settings or documents since the text cannot be detected correctly. - Resolution is outside the range of 300 dpi to 600 dpi - Font size is outside the range of 8 points to 48 points - Documents containing special fonts, effects, italics, or hand-written text - Documents with patterned backgrounds In that case, select the Check scan results checkbox and rotate the image in the Save Settings dialog box.
Save Settings Dialog Box When Select Source is Auto
(2) Save Settings Area-
File Name Enter the file name of the image to be saved. The date and 4 digits are appended to the set file name in the "_20XX0101_0001" format. -
Data Format Select the data format in which to save the scanned images. You can select JPEG/Exif, TIFF, PNG, PDF, PDF (Multiple Pages), or Auto.
Important -
When Auto is selected, the save format may differ depending on how you place the item. See "Placing Items (When Scanning from a Computer)" for details on how to place items. -
When Start OCR is selected in Application Settings, you cannot select PDF or PDF (Multiple Pages).
Note -
Settings... Click to display the Data Format Settings dialog box in which you can set the quality of the images to be saved, keyword search of PDF files and their compression type, and the data format in which to save images scanned with Auto Scan.
Data Format Settings Dialog Box -
Save in Displays the folder in which to save the scanned images. To change the folder, specify the destination folder in the Select Destination Folder dialog box displayed by selecting Add... from the pull-down menu. The default save folders are as follows. Windows 8: My Documents folder Windows 7: My Documents folder Windows Vista: Documents folder Windows XP: My Documents folder
Important -
Check scan results Displays the Save Settings dialog box after scanning.
Important -
This does not appear when Select Source is Auto. -
After scanning from My Image Garden, the Save Settings dialog box does not appear.
(3) Application Settings Area-
Open with an application Select this when you want to enhance or correct the scanned images. You can specify the application from the pull-down menu. -
Send to an application Select this when you want to use the scanned images as they are in an application that allows you to browse or organize images. You can specify the application from the pull-down menu. -
Send to a folder Select this when you also want to save the scanned images to a folder other than the one specified in Save in. You can specify the folder from the pull-down menu. -
Attach to e-mail Select this when you want to send e-mails with the scanned images attached. You can specify the e-mail client you want to start from the pull-down menu. -
Start OCR Select this when you want to convert text in the image into text data using specified OCR software. You can specify the application from the pull-down menu. -
Do not start any application Saves to the folder specified in Save in.
Note -
Instructions Opens this guide.
