Salesforce
Printing Network information from IP7220
« Go Back
Information
TitlePrinting Network information from IP7220
URL NameART143014
Description
This article explains how to print a Network Configuration Page from the PIXMA iP7220.  An example of this page is attached to this article.
Solution
 The steps listed below are specific to the iP7220.  For instructions for other models, click here.
You can print out the network settings of the printer such as its IP address and SSID.
 This print out contains valuable information about your computer. Handle it with care.
  1. Make sure that the printer is powered on.
  2. Load a sheet of A4 or Letter-sized plain paper.
  3. Press and hold the RESUME/CANCEL button until the POWER lamp flashes 6 times.
  4. Release the RESUME/CANCEL button.
    The printer starts printing the network setting information.
    The following information on the printer's network setting is printed out.
    Item
    Explanations of the item
    Setting
    Wireless LAN
    Wireless LAN
    Enable/Disable
    Connection
    Status of the Wireless LAN
    Active/Inactive
    MAC Address
    MAC Address
    XX:XX:XX:XX:XX:XX
    SSID
    SSID
    SSID of the wireless LAN
    Communication Mode
    Communication Mode
    Infrastructure
    Channel
    Channel
    XX (1 to 13)
    Encryption
    Method of the Encryption
    none/WEP/TKIP/AES
    WEP Key Length
    WEP Key Length
    Inactive/128/64
    Authentication
    Method of the Authentication
    none/auto/open/shared/WPA-PSK/WPA2-PSK
    Signal Strength
    Signal Strength
    0 to 100 [%]
    TCP/IP Version
    TCP/IP Version
    IPv4 & IPv6/IPv4
    IPv4 IP Address
    Selected IP Address (IPv4)
    XXX.XXX.XXX.XXX
    IPv4 Default Gateway
    Default Gateway (IPv4)
    XXX.XXX.XXX.XXX
    Subnet Mask
    Subnet Mask
    XXX.XXX.XXX.XXX
    IPv6 IP Address *1
    Selected IP Address (IPv6)
    XXXX.XXXX.XXXX.XXXX
    XXXX.XXXX.XXXX.XXXX
    IPv6 Default Gateway *1
    Default Gateway (IPv6)
    XXXX.XXXX.XXXX.XXXX
    XXXX.XXXX.XXXX.XXXX
    Subnet Prefix Length*1
    XXX
    IPsec*2
    IPsec setting
    Active
    Security Protocol*2
    Method of the Security Protocol
    ESP/ESP & AH/AH
    WPS PIN CODE
    WPS PIN code
    XXXXXXXX
    Wireless LAN DRX
    Discontinuous reception (wireless LAN)
    Enable/Disable
    Other Settings
    Other settings
    Printer Name
    Printer name
    Printer name (Up to 15 characters)
    WSD
    WSD setting
    Enable/Disable
    WSD Timeout
    Timeout
    1/5/10/15/20 [min]
    LPR Protocol
    LPR protocol setting
    Enable/Disable
    Bonjour
    Bonjour setting
    Enable/Disable
    Bonjour Service Name
    Bonjour service name
    Bonjour service name (Up to 52 characters)
    IP Address Filtering
    Enable/Disable
    ("XX" represents alphanumeric characters.)
    *1 Only when IPv6 is activated, the status of the network is printed.
    *2 Only IPv6 and the IP sec setting are activated, the status of the network is printed.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
