Installing Canon PRINT on your smartphone/tablet allows you to perform copy settings or operations from your smartphone / tablet.
Canon PRINT is a Canon-made application and can be downloaded from the App Store (iOS / iPadOS) and Google Play (Android and ChromeOS).
Make sure that the printer is turned on.
Load paper into the appropriate source.
Connect the printer and your device.
Connection with a router
Direct Connect / Access Point Mode
Start Canon PRINT from your device.
Make sure your printer is selected.
If not, select your printer.
Select Copy on the main menu.
Specify settings as necessary.
The setting items below are available.
Copies
Paper Size
Media Type
Magnification
Copy Intensity
Print Quality
Load the original document on the platen (scanner) glass or in the ADF (Auto Document Feeder).
Select Color Copy in the application for color copying or Black Copy for black & white copying.
If a screen asking you to enter a password is displayed, enter the printer's password (usually the printer's serial number) and select OK in the application.
If asked to save the password, select Save, Not now, or Do not save.
The machine starts copying.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
