Learn how to use the Easy Wireless Connect method to connect your PIXMA TS6120 wirelessly.
If your Mac has macOS® 10.14 or later installed, the driver and software package for this printer is not supported on your computer. Learn how to wirelessly set up your printer on a Mac with macOS® 10.14 or later.
The PIXMA TS6120 printer must first be connected to the wireless network to print and scan wirelessly, and the correct drivers and software must be installed on the computer.
The setup process consists of 2 parts.
- Start Easy Wireless Connect
- Download and run the setup files
1. Start Easy Wireless Connect
- Make sure that the printer is turned on. If the power is on, the power lamp (A) will be lit.
-19?scl=1)
If the printer is performing any process, wait for the process to finish, before starting setup.
(Appears in a new window)
- Tap HOME (B) on the printer.
If an error screen is displayed, tap OK, then tap HOME.
-16?scl=1)
- Select
(C).
- Select LAN settings.
- Select Wireless LAN.
- Select Wireless LAN setup.
- Select Easy wireless connect.
- Select Yes.
- When the printer preparation is complete, the screen below appears.
Return to the setup application screen and proceed with the setup.
2. Download and run the setup file.
Follow the link to get the setup file, find the file compatible with your computer's operating system and tap Download. Once you download the files you can follow the steps below to complete the setup process.
Start setup. Tap Next on the first screen.
Enter your computer User Name and Password then select Install Helper.
Select Start Setup.
Select appropriate region and tap Next.
Select Yes on the License Agreement.
Select Agree or Do Not Agree to the Survey.
Status check occurs.
Select Yes on the Connection Method.
Setup continues. If the Select wireless router screen (below) appears, select the wireless router to connect to the printer, enter the Network Key (password) and tap Next.
The router being used and its network settings determines whether or not this screen appears.
Network Connection completed. Tap Next.
The installation continues.
If the following appears, select Allow.
Tap Add Printer on the Add Printer screen.
On the Add screen, select the TS6100 series with Bonjour Multifunction listed in the Kind column. Select AirPrint or Secure AirPrint from Use dropdown list. Tap Add.
Tap Next on the Add Printer screen.
Tap Next.
Setup complete. Tap Next.
Select any optional software desired. Tap Next.
Tap Next.
Select Next or Skip.
Tap Exit.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
TS6120 Page
