Salesforce
Set up a Mac to work with the PIXMA TS6120 on a Network - macOS 10.14 or later
« Go Back
Information
TitleSet up a Mac to work with the PIXMA TS6120 on a Network - macOS 10.14 or later
URL NameART176552
Description
If your Mac® has macOS 10.14 or later installed, the Easy Wireless Connect method is not available for your computer. Alternative methods for setting up your printer are available.
Solution
 If your Mac has macOS® 10.14 or later installed, the driver and software package for this printer is not supported on your computer. You won't be able to use the Easy Wireless Connect method to connect the printer to your wireless network. You'll need to use a different method to connect the printer to your network:
 After connecting the printer to your wireless network via one of the methods listed above, download the following software from the Canon USA website:
  • IJ Scan Utility Lite
  • My Image Garden
 After installing the software, add the printer to your computer's printer list:
  1. Select the Apple menu, select System Preferences, and select Printers & Scanners on your Mac.
  2. Select + to display the printer list.
  3. Select the printer's name listed as Bonjour Multifunction.
  4. Select AirPrint or Secure AirPrint from Use.
  5. Select Add.
Your printer is now ready for use on your wireless network from your Mac.
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
Link to Canon Community Forum
____________________________________________________________________________________________
Powered by
