Salesforce
Device User Settings - TR8520
« Go Back
Information
TitleDevice User Settings - TR8520
URL NameART172102
Description
Date / time setting
Solution
  • Date display format
    Changes the display format of dates when printed.
     Note
  • Daylight saving time setting
    Enables/disables the summer time setting. If you select ON, you can select additional sub-settings. This setting may not be available depending on the country or region of purchase.
    • Start date/time
      Sets the date and time that summer time starts.
      Month: Specify the month.
      Week: Specify the week.
      DOW: Specify the day of the week.
      The screen to set the shift time to start summer time will be displayed after specifying the items above and selecting OK.
      After specifying the shift time and selecting OK, you can specify the end date/time.
    • End date/time
      Sets the date and time that summer time ends.
      The screen to set the shift time to end summer time will be displayed after specifying the items above and selecting OK.
      Specify the shift time and select OK.
  • Sound control
    Selects the volume.
    • Keypad volume
      Selects the beep volume when tapping the touch screen.
    • Alarm volume
      Selects the alarm volume.
    • Line monitor volume
      Selects the line monitor volume.
    • Offhook alarm
      Selects the alarm volume when the phone receiver is not put on the hook properly.
  • Country or region
    Selects the country or region where you are using the printer.
     Note
    • This setting may not be available depending on the country or region of purchase.
  • Device info sending settings
    Selects whether you will send the printer usage information to Canon server. The information sent to Canon will be utilized to develop better products. Select Agree to send the printer usage information to Canon server.
  • Energy saving settings
    Allows you to turn on/off the printer automatically to save electricity.
    • Auto power off
      Specifies the length of time to turn off the printer automatically when no operation is made or no printing data is sent to the printer.
    • Auto power on
      Selecting ON enables the printer to turn on automatically when a scanning command from a computer or printing data is sent to the printer.
     Note
    • You can also enter this setting menu by selecting ECO settings and Energy saving settings on the HOME screen.
  • Document removal reminder
    Selects whether the printer will display the reminder screen in case you forget to remove the original from the platen glass after scanning.
     Important
    • Depending on the type of original or the state of the document cover, forgetting to remove the original may not be detected.
  • Bluetooth settings
    Setting items for connecting with Bluetooth compatible device.
    • Enable/disable Bluetooth
      Enables/disables the Bluetooth function of the printer.
    • List/delete paired devices
      Displays the list of paired Bluetooth compatible devices. To delete the paired Bluetooth compatible device, select a Bluetooth compatible device from the list.
    • Check/change PIN code
      Allows you to check the PIN code and change it.
       Important
      • When you change the PIN code, pairing with all Bluetooth compatible devices is canceled.
    • Set Bluetooth device name
      Specifies the printer name for Bluetooth connection.
     Note
TR8520 Page
Powered by
