Setting Up Envelope Printing
Load envelopes in the printer.
Open the printer driver setup window.
Select Envelope from Commonly Used Settings on the Quick Setup tab.
When the Envelope Size Setting dialog box is displayed, select Envelope Com 10, Envelope DL, Yougata 4 4.13"x9.25", or Yougata 6 3.86"x7.48", and then click OK.
To print the addressee horizontally, select Landscape for Orientation.
If Envelope Com 10, Envelope DL, Yougata 4 4.13"x9.25", or Yougata 6 3.86"x7.48" is selected for Printer Paper Size, the printer rotates the paper 90 degrees to the left to print, regardless of the Rotate 90 degrees left when orientation is [Landscape] setting for Custom Settings in the Canon IJ Printer Assistant Tool.
Select High or Standard that matches your purpose for Print Quality.
Click OK.
When you print, the information is printed on the envelope.
If the paper settings in the printer driver differ from the paper information registered on the printer, an error may occur. For instructions on what to do if an error occurs, see Paper Settings.
To check the current printer settings or to apply the printer settings to the printer driver, click Printer Media Information... from the Quick Setup tab, and specify the settings in the dialog box that appears.
For details about the paper information to be registered on the printer, see the following:
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
