Your PIXMA G6020 can be set up to work wirelessly with a Windows PC via a method known as Easy Wireless Connect. This method will allow your computer to send information directly to the printer so that it can connect to your wireless network. To set up your PIXMA G6020 using this method with the Setup CD or the IJSetup website, follow the steps below.
Insert the Setup CD that came with your printer. If you receive a prompt asking you to specify what action to take after the Setup CD has been inserted into the computer, select Run Msetup4.exe. If you do not receive a prompt, open This PC or Computer and navigate to your CD-ROM or DVD-ROM drive (usually D:). Double click Msetup4.exe.
If you do not have the Setup CD, or if your computer does not have a CD-ROM or a DVD-ROM drive, click here, then click Download. If you are prompted to run or save the file, save it to your computer, then open it. This will launch the Full Driver & Software Package for your printer.
When the setup program begins, click Start Setup.
If you are using the Setup CD, you will have an option labeled Use the updated software found on Internet. If this box is checked, the setup program will check for the most up to date versions of the drivers and software available for your printer. If the box is not checked, the setup program will install the drivers and software contained on the Setup CD.
If you are using the Full Driver & Software Package, Use the updated software found on Internet will not be shown on this screen.
Click Next.
If you are using the Full Driver & Software Package, or if you are using the Setup CD and selected the option Use the updated software found on Internet, the setup program will acquire information on the latest drivers and software for your printer. This may take several minutes depending on the speed of your internet connection.
The installer will process for a few moments.
Select your country or place of residence. Then, click Next.
Read through the License Agreement. Click Yes to proceed.
If you are using the Full Driver & Software Package, or if you are using the Setup CD and selected the option Use the updated software found on Internet, the setup program will bring up an agreement regarding using services related to your printer. Read this agreement, then click Agree or Do not agree to proceed.
The setup program will process for a few moments and check the printer's status.
On the Select Connection Method screen, click Wi-Fi Connection. Then, click Next.
On the Check Power screen, click Next.
The setup program will search for the printer on the network.
On the Connecting Printer to Network screen, click Next.
Press and hold the Wireless Connect
button for 3 seconds. Then, click Next.
The setup program will search for the printer. This may take up to one minute.
You will be asked to connect your printer to a wireless router. Click Yes.
The computer will disconnect from your network and temporarily connect to the printer and send the network information to it. The computer will then reconnect to your wireless network.
If the printer is not detected on the network, make sure of the following:
Make sure that your computer has reconnected to your wireless network.
Make sure that there is no firewall or other security software currently running that may be blocking communication. If you have firewall or other security software, temporarily disable this software, or configure the software to allow communication with the ports needed for the printer. Refer to the documentation for your firewall or security software for more information.
Click Next.
The setup program will then begin installing the drivers for your printer.
If you are using the Full Driver & Software Package, or if you are using the Setup CD and selected the option Use the updated software found on Internet, the setup program will download the drivers for your printer and then begin installing them. This may take several minutes depending on the speed of your internet connection.
The printer will then be registered in your computer. This may take a few moments.
On the Test Print screen, load paper into the printer and click Start to print a test page. Click Next to proceed.
You can skip the test print by clicking Next.
The Setup Complete screen will appear. If you want this printer to be the default printer for your computer, place a check in the box for Set as default printer. If you have other printers installed and do not want this printer as the default printer, remove the check from this box. Then, click Next.
The Software Installation List will appear. Place a check in the boxes for the software you want to install. Then, click Next.
Note that the software available for installation will vary depending on if you are using the Full Driver & Software Package or if the Setup CD with the option Use the updated software found on Internet.
Setup CD:
Full Driver & Software Package or if the Setup CD with the option Use the updated software found on Internet is selected:
The chosen software will be installed.
Setup CD:
In this instance, the selected software will be downloaded and then installed. This may take several minutes depending on the speed of your internet connection.
If you are using the Setup CD and you did not select the option for Use the updated software found on Internet, proceed to step 18.
After the software has been installed, you will be prompted to register your printer. Click Skip to bypass this process, or click Register Now to register your printer. Follow any on-screen instructions.
After the installation has completed, click Exit. By default, the option Restart the system now (recommended) will be selected. If you want to restart your system after finishing the installation, leave this box checked and click Exit. If you do not want to restart, remove the check and click Exit.
The drivers and software are installed and your printer is now ready for use with your PC.
For support and service options, sign into (or create) your Canon Account from the link below.
My Canon Account
