Salesforce
Support Code 2103 Appears - MG3620
« Go Back
Information
TitleSupport Code 2103 Appears - MG3620
URL NameART176499
Description
Learn how to troubleshoot support code 2103 when printing with the PIXMA MG3620.
Solution
2103
Cause
Machine cannot detect paper size.
What to Do
Press the machine's Stop button and try to print again.
If this error still occurs even after printing again, set the machine not to detect the paper width by using the operation panel, the printer driver, or Remote UI.
 Depending on the type of paper, the machine may not detect the paper width.
 If the paper output cover is opened while printing is in progress, the machine may not detect the paper width.
To toggle the paper width detection function of the printer from the operation panel:
  1. With the printer powered on, press and hold the Stop button until the Alarm lamp flashes 15 times, then release the button.
  2. Press the Black button to disable paper width detection. Press the Color button to enable paper width detection.
If your product issue was not resolved after following the steps above, or if you require additional help, please create or log in to your Canon Account to see your technical support options.
Powered by
