Salesforce
Paper Types You Can Use - PRO-200
« Go Back
Information
TitlePaper Types You Can Use - PRO-200
URL NameART177827
Description
Learn about various Paper types supported by the PIXMA PRO-200.
Solution
Supported Media Types
For best results, choose paper designed for how you are printing. A variety of paper for documents as well as photos or illustrations is available from Canon. Use genuine Canon paper to print important photos, when possible.
Media Types
Genuine Canon paper
 For warnings on use of the non-printable side, see each product's usage information.
 Page sizes and media types differ depending on the country or region where the paper is sold. For details on page sizes and media types, visit the Canon website.
 Genuine Canon paper is not available in some countries or regions. Note that in the United States, Canon paper is not sold by model number. Instead, purchase paper by name.
Paper for printing documents:
  • Canon Red Label Superior <WOP111>
  • Canon Océ Office Colour Paper <SAT213>
  • High Resolution Paper <HR-101N>
Paper for printing photos:
  • Photo Paper Pro Platinum <PT-101>
  • Glossy Photo Paper "Everyday Use" <GP-501>
  • Photo Paper Glossy <GP-701>
  • Photo Paper Plus Glossy II <PP-201/PP-208/PP-301>
  • Photo Paper Pro Luster <LU-101>
  • Photo Paper Plus Semi-gloss <SG-201>
  • Matte Photo Paper <MP-101>
  • Photo Paper Pro Premium Matte <PM-101>
  • Premium Fine Art Rough <FA-RG1>
Paper for making original goods:
  • Printable Nail Stickers <NL-101>
  • Light Fabric Iron-on Transfers <LF-101>
  • Dark Fabric Iron-on Transfers <DF-101>
  • Double sided Matte Paper <MP-101D>
Paper other than genuine Canon paper
  • Plain Paper (including recycled paper)
  • Envelopes
  • T-Shirt Transfers
  • Greeting Card
  • Card Stock
 See how much paper can be loaded into the printer.
 Learn about the media type settings found in the Windows printer driver and the printer's operation panel.
 Learn about the media type settings found in the macOS printer driver and the printer's operation panel.
 When printing photos saved on a PictBridge (Wi-Fi) compliant device, you must specify the page size and media type.
 When using art paper, see Before Printing on Art Paper.
Page Sizes
You can use the following page sizes.
 Page sizes and media types the printer supports differ depending on the OS you are using.
Standard sizes:
  • top feed
    • Letter
    • Legal
    • 11"x17"(28x43cm)
    • A5
    • A4
    • A3
    • A3+
    • B5
    • B4
    • KG/4"x6"(10x15)
    • 5"x7"(13x18cm)
    • 7"x10"(18x25cm)
    • 8"x10"(20x25cm)
    • 10"x12"(25x30cm)
    • 210x594mm
    • L(89x127mm)
    • 2L(127x178mm)
    • Square 5"
    • 12"x12"(30x30cm)
    • Hagaki
    • Hagaki 2
    • Envelope Com 10
    • Envelope DL
  • manual feed tray
    • Letter
    • Legal
    • 11"x17"(28x43cm)
    • A4
    • A3
    • A3+
    • B4
    • 8"x10"(20x25cm)
    • 10"x12"(25x30cm)
    • 210x594mm
    • 12"x12"(30x30cm)
Special sizes
Special page sizes must be within the following limits:
  • top feed
    • Minimum size: 3.50 x 5.00 in. (89.0 x 127.0 mm)
    • Maximum size: 12.95 x 39.00 in. (329.0 x 990.6 mm)
  • manual feed tray
    • Minimum size: 8.00 x 10.00 in. (203.2 x 254.0 mm)
    • Maximum size: 13.00 x 39.00 in. (330.2 x 990.6 mm)
Paper Weight / Thickness
You can use paper in the following weight/thickness ranges.
* Do not use paper heavier or thicker than this, as it could jam in the printer.
  • top feed
    Plain paper: From 17 to 28 lb (64 to 105 g /m2)
    Specialty paper: Up to 80 lb (300 g /m2) / from 4 to 11.8 mil (0.1 to 0.3 mm)
  • manual feed tray
    Specialty paper: Up to 93 lb (350 g /m2) / from 4 to 23.6 mil (0.1 to 0.6 mm)
Powered by
