Salesforce
Summary of Reports and Lists - TR8520
« Go Back
Information
TitleSummary of Reports and Lists - TR8520
URL NameART170892
Description
Fax reports
Solution
The printer prints the report of sending or receiving a fax automatically. You can print the list of the fax/telephone number or the current settings.
Type of Reports and Lists
Report or List
Description
ACTIVITY REPORT
Shows recent fax transactions at sight.
  • You can print ACTIVITY REPORT manually.
    For details on the procedure to print, see Printing Report or List.
  • The * (asterisk) is appended to the history already printed on ACTIVITY REPORT.
  • If you select Print for Activity report in Auto print settings under FAX settings, the printer prints ACTIVITY REPORT for the 20 histories of sent and received faxes automatically.
Directory list
  • RECIPIENT TELEPHONE NUMBER LIST
  • GROUP DIAL TELEPHONE NO. LIST
Lists the numbers and names registered.
You can print the lists of the recipient and group dial.
USER'S DATA LIST
Lists the current settings of the printer and the registered sender information.
MEMORY LIST
Lists the documents currently stored in the printer's memory.
 Note
REJECTED NUMBER LIST
Lists the rejected numbers.
CALLER HISTORY
Lists the caller history.
This list is available when Caller ID service is subscribed.
This list may not be supported depending on the country or region of purchase.
TX REPORT/ERROR TX REPORT
Either of these reports is printed after each fax transmission.
  • At the time of purchase, ERROR TX REPORT is set to be printed only when a transmission error occurred.
    You can set the printer to print TX REPORT each time it sends a document, or disable printing of the report by selecting TX report in Auto print settings under FAX settings.
    You can also specify the print setting so that the first page of the fax is printed along with the report.
     Note
    • The first page of the fax is not printed in color transmission.
  • MULTI TRANSMISSION REPORT is printed after sequential broadcasting of a document.
  • If an error occurs when you send a fax, the error number is printed on ERROR TX REPORT (there are some errors for which the cause is also printed).
    For details on the error number, see Errors When You Send Fax.
This report is printed after sequential broadcasting of a document.
Confirms whether the transmission to all the recipients has been completed successfully.
The procedure to print and the error number is same as TX REPORT.
RX REPORT
This report is printed after each fax reception.
  • At the time of purchase, the printer is set so that RX REPORT is not printed at all.
    You can set the printer to print RX REPORT each time it receives a document, or only when an error occurs by selecting RX report in Auto print settings under FAX settings.
  • If an error occurs when you receive a fax, the error number is printed on RX REPORT (there are some errors for which the cause is also printed).
    For details on the error number, see Errors When You Receive Fax.
MEMORY CLEAR REPORT
Lists the deleted faxes in the printer's memory if the faxes stored in the printer's memory are deleted by a power failure or unplugging the power cord.
When the printer is turned on, The power cord has been unplugged and unsent/received docs in memory have been lost. Load paper and tap [OK] to print a list of the lost docs. is displayed on the touch screen. MEMORY CLEAR REPORT is printed by selecting OK on the touch screen.
This section describes the procedure to print the report or the list manually.
Print the following report or list manually.
  • ACTIVITY REPORT
  • Directory list (RECIPIENT TELEPHONE NUMBER LIST/GROUP DIAL TELEPHONE NO. LIST)
  • USER'S DATA LIST
  • MEMORY LIST
  • REJECTED NUMBER LIST
  • CALLER HISTORY
     Note
    • CALLER HISTORY may not be supported depending on the country or region of purchase.
  1. Make sure that printer is turned on.
  2. Load paper.
  3. Select FAX on the HOME screen.
    The Fax standby screen is displayed.
  4. Select Function list.
    The Function list screen is displayed.
  5. Select Print reports/lists.
  6. Select a report or a list you want to print to start printing.
    • When you select Directory list:
      Select Recipient or Group dial.
      If you select Recipient, select whether to print RECIPIENT TELEPHONE NUMBER LIST in alphabetical order. If you select Yes, the printer prints RECIPIENT TELEPHONE NUMBER LIST in alphabetical order. If you select No, the printer prints RECIPIENT TELEPHONE NUMBER LIST in numerical order.
      If you select Group dial, the confirmation screen is displayed. Select Yes. The printer prints GROUP DIAL TELEPHONE NO. LIST.
    • When you select an item other than Directory list:
      Select Yes when the confirmation screen is displayed.
      The printer prints the selected report or list.
If an error occurs when you send a fax, the error number is printed on ERROR TX REPORT or ACTIVITY REPORT (there are some errors for which the cause is also printed).
The causes corresponding to the error numbers are as follows.
No.
Cause
Action
#001
Document is jammed in the ADF.
The document is jammed in the ADF.
When the error is cleared, redo the operation.
#003
Document is too long.
You attempted to send a document longer than 15.75 inches / 400 mm.
You cannot send a document longer than 15.75 inches / 400 mm from the ADF.
"#003" is also printed if it takes time to send a page. Divide the document or set the image quality (Fax resolution) to a lower setting, and then resend it.
#005
No answer.
The recipient's fax device does not respond.
Contact the recipient and have the recipient check that the telephone line is connected correctly.
#012
No paper is in the recipient's fax device.
There is no paper in the recipient's fax device.
Contact the recipient and have the recipient load paper.
#017
No tone is detected.
The printer could not detect the dial tone.
Dial tone detect in Advanced FAX settings under FAX settings is set to ON. Set to OFF.
#018
Line was busy.
The fax/telephone number you dialed is busy.
Try dialing again after waiting for a moment.
#022
Number is deleted.
The fax/telephone number registered in the printer's directory is incorrect.
Check the recipient's fax/telephone number, correct the fax/telephone number registered in the printer's directory, and then send the document again.
#037
Memory is full.
The printer could not send a fax because its memory is full.
Delete contents in memory, and then send a fax again.
#059
Transmission has been canceled due to a fax information mismatch.
Transmission has been canceled because the printer could not detect the recipient's fax device information or the information did not match the dialed number. This message is displayed when Check RX FAX information in Security control under FAX settings is set to ON.
For details, see Sending Faxes after Checking Information (Checking Recipient's Information).
#085
Try again in black & white transmission.
The recipient's fax device is not color-compatible.
Resend the document in black & white.
#099
The Stop button was pressed during transmission.
The Stop button was pressed to cancel transmission of the document. Resend it if necessary.
#412
The fax could not be sent from the computer.
The fax could not be sent from the computer. Ensure that the printer is connected with the computer correctly and redo operation.
#995
The unsent fax was deleted while automatic redialing.
While automatic redialing, the unsent fax is stored in the printer's memory temporarily until the sending fax is complete. If a power failure occurs or you unplug the power cord before automatic redialing is complete, all faxes stored in the printer's memory are deleted and not sent.
Resend the document.
If an error occurs when you receive a fax, the error number is printed on RX REPORT or ACTIVITY REPORT (there are some errors for which the cause is also printed).
No.
Cause
Action
#003
It takes too long to receive a page.
Contact the sender and have the sender divide the fax or set the image quality (Fax resolution) to a lower setting and resend it.
#005
No answer.
When receiving a fax manually, the printer could not detect the signals from the sender's fax device.
Contact the sender and have the sender resend it, or set the printer to receive the fax automatically.
#037
Memory is full.
The printer could not receive a fax because its memory is full.
Delete contents in memory, and then ask the sender to resend the fax. See Document Stored in Printer's Memory.
#046
Reception has been rejected due to the specified fax rejection condition.
Reception has been rejected because the fax matches the fax rejection condition specified by FAX reception reject in Security control under FAX settings.
For details, see Rejecting Fax Reception.
#099
The Stop button was pressed during reception.
The Stop button was pressed to cancel reception of the fax. Contact the sender and have the sender resend it if necessary.
#995
The received fax was deleted.
The received fax was deleted before being printed. Contact the sender and have the sender resend it if necessary.
Powered by
