Salesforce
Manage FAX Settings on a PIXMA TR8520
« Go Back
Information
TitleManage FAX Settings on a PIXMA TR8520
URL NameART168116
Description
Learn more about the FAX settings on your PIXMA TR8520.
Solution
This article explains how to manage various fax settings on your machine. Refer to the following to learn how to send a fax.
Before you manage settings
  • You will need to prepare your printer for faxing.
  • To confirm or make a copy of your current fax settings, you can print the USER'S DATA LIST.
  • To access fax settings from the operation panel, select:  Cog wheel icon  forward arrow Settings  forward arrow Device settings  forward arrow FAX settings.
FAX user settings
From the fax user settings, you can manage the following:
Advanced FAX settings
From advanced fax settings, you can manage the following:
  • Error reduction setting (VoIP) - Select Reduce to limit communication errors when you connect to an Internet line such as an IP phone.
  • Auto redial - Select ON to specify the maximum number of redial attempts and the length of time the printer waits between redials.
  • Dial tone detect - Select ON to confirm a dial tone before the fax is sent. (This setting may not be available depending on the country of purchase.)
  • Pause time settings - Set the length of the pause time when you enter "P" (pause).
  • TTI position - Select the position of the sender information (outside or inside the image area).
  • Remote RX - Select ON to specify the remote reception ID.
  • Color transmission - Select Disconnect if you don't want to send color documents when the recipient's fax doesn't support color faxes.
  • RX image reduction - Select ON to enable / disable automatic reduction, which decreases the size of incoming faxes so they fit on the selected paper.
  • Adv. communication settings
    • ECM TX - Select whether to send faxes in Error Correction Mode.
    • ECM RX - Select whether to receive faxes in Error Correction Mode.
      • TX start speed - Select the fax transmission speed. When the phone line condition or connection is poor, a lower transmission speed may resolve the issue.
      • RX start speed - Select the fax reception speed. When the phone line condition or connection is poor, a lower reception speed may resolve the issue.
    Auto print settings
    • Received documents - Select Do not print to automatically store a received fax in the printer's memory.
    • Activity report - Select Print to print an ACTIVITY REPORT of the last 20 fax transactions (sent and received).
    • TX report - Select Print error only or Print for each TX to automatically print a TX REPORT/ERROR TX REPORT after a fax is sent.
    • RX report - Select Print error only or Print for each RX to automatically print a RX REPORT after a fax is received.
    • Print when out of ink - Set this to continue printing when ink runs out. Note that part or all of the fax may not print if the ink is out.
    Auto save setting
    Security control
    • FAX number re-entry - Select ON to send faxes after entering the number twice. Use this setting to prevent mistransmission of faxes.
    • Check RX FAX information - Select ON to have the printer make sure the recipient's fax device matches the dialed number. If it matches, the printer sends the fax.
    • Hook key setting - Select Enable to use the on-hook dial function.
    • FAX reception reject - Select ON, and the printer rejects fax reception if there is no sender information or the fax comes from specific senders.
    • Caller rejection - Select Yes on the subscribing confirmation screen to use your Caller ID to reject calls.  (This setting may not be available depending on the country of purchase.)
    Powered by
