Wireless Connection
Prior to starting setup on the Computer, Smartphone or tablet device, start the Easy wireless connect on the printer. Then complete the setup on the computer or device.
See the procedure below to start the Easy Wireless connect.
Make sure that the printer is turned on.
If the power is on, the POWER lamp (A) will be lit.
-9?scl=1)
If the printer is performing cleaning, print head alignment, or other processes
Wait for the process to finish, before starting setup.
Press the HOME button (B) on the printer.
If an error screen is displayed, press the OK button, then press the HOME button.
-6?scl=1)
Use the
buttons (C) to select
(D).
?scl=1)
Press the OK button.
Select LAN settings and press the OK button.
-7?scl=1)
Select Wireless LAN and press the OK button.
-3?scl=1)
Select Wireless LAN setup and press the OK button.
Select Easy wireless connect and press the OK button.
-31?scl=1)
Select Yes and press the OK button.
When the printer preparation is complete, the screen below appears.
-19?scl=1)
The printer is ready to receive the information it needs to connect to a wireless network. Select the computer or device you have for instructions on connecting the printer to your wireless network.
Windows
macOS
If you have macOS 10.15 or later, you'll need to use an alternate method to connect the printer to your network.
iOS / iPadOS
Android
Or if you still need help, visit our Canon Community by clicking the button below to get answers:
____________________________________________________________________________________________
