If your Mac is running macOS 10.14 or later, you will need to follow a different sequence of steps to set up the Mac to work with the printer wirelessly.
If the printer won't connect to your wireless network via any of the methods in step 1, you can use the Canon IJ Network Tool to connect the printer to the network. You'll need a USB cable if you want to connect the printer to your network using this method.
