Salesforce
Starting Easy Wireless connect on the TS9120
« Go Back
Information
TitleStarting Easy Wireless connect on the TS9120
URL NameART168173
Description
Preparations to connect to a Wireless LAN
Solution
Wireless Connection
Prior to starting setup on the Computer, Smartphone or tablet device, start the Easy wireless connect on the printer.  Then complete the setup on the computer or device.
See the procedure below to start the Easy Wireless connect.
  1. Make sure that the printer is turned on.
    If the power is on, the POWER lamp (A) will be lit.
    figure: POWER lamp lights up
    (Appears in a new window)
If the printer is performing cleaning, print head alignment, or other processes
Wait for the process to finish, before starting setup.
  1. If HOME is displayed on the left side of the screen, tap HOME.
    If an error screen is displayed, tap OK, then tap HOME.
    HOME screen
  2. Tap Network status (B).
    HOME screen: Select Network status
  3. Tap LAN settings.
    Basic network information screen: Select LAN settings
  4. Tap Wireless LAN.
    LAN settings screen: Select Wireless LAN
  5. Tap Wireless LAN setup.
    Wireless LAN screen: Select Wireless LAN setup
  6. Tap Easy wireless connect.
    Other setup screen: Select Easy wireless connect
  7. Tap Yes.
    Easy wireless connect screen: Settings will be made on a computer or smartphone, etc.
  8. When the printer preparation is complete, the screen below appears.
    Return to the setup application screen and proceed with the setup.
    Easy wireless connect screen: Follow the instructions on the computer or smartphone, etc. to perform the operation.
Wireless Setup on Windows Computers
Wireless Setup on Mac Computers
Wireless Setup on Android Phone and Tablets
Wireless Setup on iOS Devices (iPad, iPhone)
Powered by
